Sponsored by: Real Truck
double cardin u joint
Old Jul 28, 2004 | 06:47 PM
getnbz's Avatar
getnbz
i have a vibration im pretty sure it in the drive train i checked the rear joint that one is tight i twisted both parts of the front joint there is a small amount of play i was wondering if i should replace and how hard to are they i dont have a press can they be done. while i was under there i saw there was some slack in the slip yoke would the vibration be coming from that how much slack should it have.
Old Jul 28, 2004 | 10:29 PM
FortyFords's Avatar
FortyFords
There should be no play in the u-joints ! the slip joint problably wasn't lubed and should be with a special grease from Ford.
The double cardigan joint is a pain ,should have a press to do and make sure you mark it in relation to all parts it is balanced as a unit.
Rich
Old Jul 29, 2004 | 12:30 AM
shapel's Avatar
shapel
the tool makers have this handy dandy tool called a u-joint press, it kind of looks like a giant "c" clamp. don't forget to remove the lock clips before using this tool, might break the yokes, also try to keep the driveshaft in phase (balancing reasons)
Old Jul 29, 2004 | 11:02 PM
getnbz's Avatar
getnbz
who makes that u joint press?
Old Jul 30, 2004 | 07:11 AM
FortyFords's Avatar
FortyFords
OTC = Otwanna Tool Company
Chk out some automotive specialty tool places online!
Rich
