Correct Throttle body and bracket help
I cannot get W.O.T on 1990 EFI 4.9 6cylinder with AOD transmission.
The motor and trans are mix match. [ long story]. I did a complete swap and cannot get full throttle unless I disconnect the AOD TV cable at throttle body.
I know the throttle cable is correct but I'm suspecting incorrect TV cable, or bracket or throttle body.
The reason I said throttle body is because Ford listed different part number for C6 trans and AOD. Other than that nobody got a clue on why there are different part number. I'm guessing the diameter of throttle body or the level assembly.
what about TV cable bracket at the trans? The one I have is mounted on driver side bell housing area.
is there a different bracket???
Can anybody shed some light on this issue?
The more I'm looking at is TV cable but the parts counter person said I got the correct cable, so I'm stumped!
I have 2 throttle body with different part number.
both lever are the same!
does anybody here have EFI 6 cylinder with AOD?
can anybody take a picture of throttle body?
