460 engine misses
Old Jul 28, 2004 | 01:54 PM
harem Scarem's Avatar
harem Scarem
460 engine misses
Hello everyone
I have a problem with my 1983 F250 with a 460 engine. It will miss at idle and gets worse as I increase acceleration to 2000-2500 rpm. The problem will worsen if I ajust my float level lower it will start to miss at lower rpms
It acts like it's not getting enough fuel or a vacume leak.
I've replaced cap,rotor,wires,spark plugs,egr valve, ignition coil, igniton module, voltage reg.,fuel filter, pressure & volume checked fuel pumps,compression tested each cylinder which ranged from 120 psi consistently except for cylinder 8 which was 95 psi, vacumed stays approx. 16-15 in hg. , checked timing, air checked selector valve.
IM just alittle stumped!!
captanron
Jun 17, 2016 11:46 PM
Eaglefixer
1983 - 2012 Ranger & B-Series
Jul 6, 2010 08:22 AM
PowerstrokeJunkie
43
Apr 30, 2008 04:50 AM
quadrazer
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Nov 10, 2004 11:42 PM
gearshift101
Jan 31, 2004 12:01 PM
