Daytime running lights
Old Feb 11, 2002 | 11:53 AM
4x4_EB_Explorer's Avatar
4x4_EB_Explorer
Hi.
I do have a question. My rear view mirror (95 EB Explorer) has buttons and a delay bar. One of this buttons (far right) when pressed, the lights turn on regardless of the position of the headlamps switch. Is this button for the daytime running lights? I know something, when this button is pressed, the lights turn on and (depending on the delay slide switch's position) these stay on after the truck is turned off.
Also... What are the other two buttons (far left) on my same mirror for? Dimming the mirror? Does the daytime running lights turn the WHOLE assembly on? (headlamp and both parking lights?)
Thanks for clearing out the confussion.
Old Feb 12, 2002 | 11:13 AM
96explorereddieb's Avatar
96explorereddieb
Your Eddie Bauer is equipped with Auto-dimming mirror with Autolamp. The function of the autolamp is to help you and the others by turning the headlights on automatically when the lighting diminishes, such as night time or an indoor garage. The autolamp function also uses a headlight-delay off feature where you can set when the headlights turn off. It ranges from 30 seconds to 3 minutes. This feature is not DRL...unless your truck was made to be used in Canada.
As to your other questions, the other buttons are for your auto-dimming mirror. I think you know how that works.
I hope this answers your questions.
Old Feb 13, 2002 | 09:10 AM
4x4_EB_Explorer
:-staun
So its called autolamp, oh, thanks that really solves some of my questions. I was under the impression that the DRL module was bad and caused the WHOLE assembly to come on. Thanks a lot. This is my first car/truck with such features and I'm still kinda $toopid when it comes to this.
Ok, I appreciatte your comment and reply.
Old Feb 13, 2002 | 12:11 PM
96explorereddieb
Hey, no problem!
Old Feb 13, 2002 | 12:25 PM
CMurph93's Avatar
CMurph93
