Sponsored by: Real Truck
differential ratio?
Old Jul 28, 2004 | 08:28 AM
Gregsd250's Avatar
Gregsd250
Question differential ratio?
I could use some help with the math on my rear differential, I have a 01 250SD
V10 Auto Trans.4:30 Ls and put 315/78X16 tires on my truck. so roughly what would my ratio be after this change? thanks
Old Jul 28, 2004 | 09:10 AM
DougD's Avatar
DougD
Go here - it is the calculator section. All the info you will need...
http://www.ring-pinion.com/calculato...latorsind.html
Old Jul 28, 2004 | 10:02 AM
Gregsd250's Avatar
Gregsd250
that don't seem to help me, I already know my tire size and ratio, I can't figure out what the final ratio is now that i have changed the tire size. i guess i need more help
Old Jul 28, 2004 | 10:12 AM
n578md's Avatar
n578md
I think I know what you want. Your truck came with 4.30 axle ratio and 265/75R16E tires (most likely) which are 31.64" tall. You put on 315/75R16 tires which are 34.60" tall so your new effective ratio would be 3.90 and you'd need a 4.70 to bring it back to stock. (4.88 is the closest avilable for a Ford/Sterling 10.5" axle.)
Old Jul 28, 2004 | 10:16 AM
Gregsd250's Avatar
Gregsd250
Thank you, Yes that is the information i was looking for. Can you show me the formula you used to figure this out?
Old Jul 28, 2004 | 10:29 AM
n578md's Avatar
n578md
To figure out the new ratio needed to bring it back to stock is:
(Original ratio x New tire diameter)/ old tire diameter = new ratio
(4.30 x 34.6) / 31.64 = 4.70
To find out what your ratio changed to after the tire swap:
old ratio - (new ratio - old ratio) = effective ratio.
4.30 - (4.70 - 4.30) = 3.90
Old Jul 28, 2004 | 11:27 AM
mattsf250's Avatar
mattsf250
i think this formula should be in the FAQ!!!!
it gets posted/requested ALOT!!!!
i know it has helped me a few times
Old Jul 28, 2004 | 02:04 PM
Gregsd250's Avatar
Gregsd250
Thanks Again that helps
Old Jul 28, 2004 | 02:31 PM
Autobahn F-250 Lariat's Avatar
here is good link for common formulas
Good "rule of thumb" calculation is to mutiply .12 by your tire diameter.
(.12 X 38" = 4.56)
http://www.4lo.com/geartable.html
Old Jul 28, 2004 | 03:22 PM
MechEngr's Avatar
MechEngr
Just got new tires for my truck... now I need to regear. Anyone know the gear ratio for a 2003 F-350, 6.0 PSD, 4x4, crew cab... blah blah blah. Thanks
Old Jul 28, 2004 | 03:29 PM
3:73 i believe
Old Jul 28, 2004 | 03:32 PM
n578md's Avatar
n578md
If its a Single Rear Wheel, then the only available ratio is 3.73. If it's a dually, it could be either a 3.73 or a 4.10.
Old Jul 28, 2004 | 05:41 PM
MechEngr's Avatar
MechEngr
yeah... its a single rear wheel. Thanks
