Axle codes info conflict
Old Jul 27, 2004 | 06:11 PM
83Van's Avatar
83Van
Question Axle codes info conflict
I have two different sets of axle ratio codes, and unfortunately they don't always match up:
Code "19", one chart says 3.55 ratio, the other 4.11 [big difference]
Code "23" appears as both 3.31 and 3.54
Code "16" as both 3.50 and 3.73
Anyone know which #'s are right...or both? Did the codes change over the years, by vehicle, or with the axle type [9", 8.8", Dana 6x]? I'd just spin the rear ends I'm looking at to verify each one, but that's very impractical the way they're situated.
any help would be greatly appreciated.
Old Jul 27, 2004 | 06:44 PM
Nod's Avatar
Nod
Axle Code
83 Van,My 77 F-150 4x4 SB has an axle code that reads 16J.There are no tags on the diffs so I do not know what the ratios are either.Is there somewhere else to find the ratio info? Thanks for any help.
"bowties in the rearview mirror"
Old Jul 27, 2004 | 09:06 PM
SoCalDesertRider's Avatar
SoCalDesertRider
19 = 3.55 open diff on later model trucks (at least '92 and later, probably starts around '80). What year and model truck are you working on?
Old Jul 28, 2004 | 03:02 PM
83Van's Avatar
83Van
This is an '83 E100 van with the 300 straight six, C6 tranny. It has a 3.00 gear right now [code 14, ford 9"] which is great for the highway but makes me slow to 30mph going uphill while towing. Looking to drop the ratio to the 3.50 -ish range for the least $$ possible. My local pick-ur-part salvage yard has several potential donor vehicles but many have bent drive shafts from being move around with a forklift, which prevents an easy "spin the wheels" ratio check.
Would prefer to just do a pumpkin swap, but the Ford 9" rears have been picked over quite a bit. Several of the late model ['88-'91] vans have a code 19 Ford 8.8" rear end, but I've seen "code 19" listed as both 3.55 and 4.11, and none are spin-checkable w/o dropping the driveshafts. 3.55 should be just right, but I fear a 4.11 would be too low and kill my mileage [no overdrive]. All these vans have a code "T" transmission, is that the AOD or E4OD??? Forgot to look at the shift indicators when I went "shopping" the other day.
Old Jul 28, 2004 | 08:16 PM
jroehl's Avatar
jroehl
"T" is an AOD. My '90 F150 is code 19 and is a 3.55 open. Hope that helps.
Jason
