Hey
ok i have a engine that used to be my grampas and its ether a 360 or a 390 but i cant tell the difference between the 2, i was wonderin if anyone out there could help my tell the difference betweenthe 2,
like mabe theres a part number i could call in on the block thats different
please help!!!
thanks
Hi I'm not positive but i just put a new marshall 360 ford in my 70' F-100 and on the part # of mine the first three numbers do say 360 (F3600C my part #). Just a guess hope it helps if not get your part # off the block and ask your local Ford Dealership.
There is no deifferance in the motors they are alike exept for crank,rods and pistons. You have to measure the stroke. but If you have the block casting number I could give you a good idea of what it should be. All FE's have 352 stanped on the drivers side front. casting #' are on the side of the block. something like cme8 or what ever it is. I can bounce that number off my index and If its never been molested it could tell you.
