96-2000 help with fuse block
Hey guys,
I've got a 2000 Mountaineer, the other day I blew the accessory 12volt outlet fuse by plugging a faulty power converter into it so I need to know which fuse it is.
Ford decided to number the fuses in the fuse block and unfortunately I don't have a manual... I thumbed thru my chilton's manual and couldn't find it, I could go thru and pull all the fuses but I figured I'd try here first.
Thanks in advance!
Thanks in advance!
I'm guessing this would be the "auxilary power" fuse & on a 97 it's under the hood, drivers side near firewall, it's a 30 amp "mini fuse". counting from right to left it's fuse 3, color is green & it's right above the fuel pump relay.
