brain teaser for tires
Old Jul 26, 2004 | 09:08 PM
SAWDUST's Avatar
SAWDUST
Question brain teaser for tires
Ok, i have a 1986 f250 4x4 that i am making into a hunting buggy so no worry about if the truck can run on the highways. it will never run over 10 mph after the conversion and only in sand and water up to 40 inches deep. presently it has 245 45 r 16 tires. i plan to lift the chassie 4 inches. i have found a great deal on 44 inch super swampers and am considering buying.
i know i will need to modify the rims from stock. rims are no problem because i can offset the hubs to whatever and add gussets for strength to fit the off road conditions--i think. my concern is can i turn the truck in a 40 acre field? i get in some tight spots on the hunting lease.
i measure the presnt turning radius at approximately 32 degrees. i couldn't find the oem radius listing in any information i have. the clearence, when driving straight ahead, between the inside of the front 245 45 r 16 tire with stock rims and the nearest obstruction is 7 1/2 inches. the 245's don't presently hit the springs or any brackets or anything else. if my calculations are correct and i offset the rim hub to the very inside of the rim and use the 44 inch tires my turning radius will be reduced to approximately 18 degrees.
what will my new turning radius be? any suggestions about modifying the rims or tires will be greatly appreciated.
thanks in advance.
