General Automotive Discussion
Bosche platinum
Old Jul 26, 2004 | 05:33 PM
longview1's Avatar
longview1
Banned
Question Bosche platinum
Just curious to what your thoughts may be on the bosche plugs with the four electrodes.
I was watching spike tv and that show "Trucks" was on, and the guy was praising them.
Anyone use them or have an opinion on em?
Old Jul 26, 2004 | 06:37 PM
fordflaresides's Avatar
fordflaresides
For what engine? In my opinion, They are overkill for old carbed motors especially with stock ignition. I don't think they even make the correct heat ranges for a lot of the older motors.
Old Jul 26, 2004 | 06:52 PM
stanz's Avatar
stanz
I haven't used the 4 electrode plugs, but I've heard of several people that used them and were unhappy. The main complaints were rough idle and pinging.
I've used the bosch platinum single electrodes on my 74 Bronco and could not distinguish any improvement over copper core plugs. I've had better luck with Autolite platinum and NGK U Groove plugs.
Beware of TV endorsements... always remember who pays their bills.
__________________
stanz
74 Bronco Sport, 302 Stock
79 F250 Camper Special, 460 4x4 Extend Cab
Old Jul 26, 2004 | 07:06 PM
Tech 1's Avatar
Tech 1
Smile 4 Electrode Plugs
The double and four electrode and split fire plugs in my humble opinion are sales gimmics. When a plug fires the electricity follows the path of least resistance and only fires off of one electrode.
Old Jul 26, 2004 | 09:00 PM
pfogle's Avatar
pfogle
I ran the standard bosch platinums in my EFI 351 for 2 weeks, the rough running and poor fuel economy from them was the reason I went back to standard motorcraft.
Old Jul 26, 2004 | 09:52 PM
MW95F250's Avatar
MW95F250
I have the 2 pole Bosch platinums in my truck, however, I can't tell you how they perform as of yet, as I put them in to try and correct the bad vibrations and missing in my truck. It helped some, but not much. I think it is an injector in conjunction with a old fuel filter.
Old Jul 27, 2004 | 07:00 PM
benwantland's Avatar
benwantland
RE: ALL FANCY SPARK PLUG DESIGNS
Folks, remember, as stated already, that electricity will always follow the path of least resistance to ground, no matter how many possible paths there are. Standard plugs = 1 spark. Fancy plugs = 1 spark.
As for platinum. The only, and I mean only, advantage of platinum spark plugs is that they last longer. You'll notice that they've come about in the last few years, coincidentally, about the same time auto engineers got bold enough to design intake manifolds that have to be removed to change plugs....
Copper is actually a better conductor than platinum, so in any vehicle where it's relatively easy to change the plugs, just save yourself a couple of bucks, and get yourself some copper plugs that will actually probably perform better anyway... just not for as long.
Old Jul 27, 2004 | 08:03 PM
250-1968_campspecial's Avatar
we used them in my moms izuzu it sitll ran like crap
Old Jul 27, 2004 | 09:32 PM
5_labsownus's Avatar
5_labsownus
I have used the bosch plugs for 20 years and never had a problem with them. I did have a problem with the split fire plugs.
The bosch plugs did not give me any increase in performance but the lifespan is greater than autolite, champion, ngk or others it have tried. The cost verses replacement time is worth the investment.
I had an Isuzu Trooper and had to replace the autolite, champion and AC about every 20,000 miles as well as the wires. With the bosch I replaced them about 60,000 miles and the wires lasted about the same.
Platinum is inert and will not erode as bad as other metals. Read some info about the Wright brothers and the engine they built for the 1903 flyer. The electrode tips were platinum for that reason. The actually touched to make a spark and any other metal would weld its self together.
