Bronco II Ford Bronco II
brakelight mixup
Old Jul 26, 2004 | 03:10 PM
jakes29's Avatar
jakes29
brakelight mixup
what would cause the brakelights and taillights to be backwards? the brake lights are dim and the tail lights are bright like brake lights. All I was doing was replacing a burnt out brake light in my 87 bII 4x4. I bought the bulb listed in the book at autozone. please help!!!
Old Jul 26, 2004 | 03:38 PM
GrayRanger4x4's Avatar
GrayRanger4x4
Sounds like you got the bulb in wrong ,take it out and turn it 180 degrees,and see if tht works.If not the contacks in the socket are tuching or 1 is broke,you will need a new socket. Is your socket a flat typ?
Old Jul 26, 2004 | 05:40 PM
jakes29's Avatar
jakes29
would a bad brake light switch have anything to do with it?
Old Jul 29, 2004 | 08:46 AM
jakes29's Avatar
jakes29
wow, I feel like the dumbest guy on this forum. I rotated the bulb 180 degrees and it worked like normal. Thats how I learn I guess. Thanks grey!
