1978 - 1996 Big Bronco
Help locating Fuel Pressure Regulator
Old Jul 26, 2004 | 08:54 AM
Wakeboarder141's Avatar
Wakeboarder141
I know this is a stupid question, but.... I am trying to test my fuel pressure, but cannot find anything in the Haynes manual that actually tells me where the FPR is. More specifically, where I connect the pressure guage. Please help.
Old Jul 26, 2004 | 09:33 AM
fcarruth's Avatar
fcarruth
Well, on my 89, it's near the driver side firewall. You will see a few hoses going to it. It is round and on a triangular shaped frome and the hex screws are accessed from the bottom side for some dumb Ford reason. It's probably about 1.5" to 2" in diameter. Worse case, go to the Zone or wherever and ask to see what your's looks like.
Hope this helps you out.
Old Jul 26, 2004 | 10:05 AM
Wakeboarder141
Ok, I think I found it. Thanks.
Old Jul 26, 2004 | 08:25 PM
jacque_strap's Avatar
jacque_strap
You connect the fuel pressure guage on a valve (looks like a tire valve) and its on the right side of your block on the fuel rail.
