Air conditioner Problems
Old Jul 26, 2004 | 08:35 AM
Inthesunshinestate's Avatar
Inthesunshinestate
I have checked the threaded discussions but I did not see any info about what I was told today. I have a 1996 Ford Explorer. My a/c slowly starting blowing hot air. Now it is completely hot. It started out as only getting cold as I accelerated to now it will not blow cold at all. I went to a chain garage (Tires Plus) and they told me I need an evaporator because it is leaking along with a dryer, orifice tube and with the labor will be $630.63. It seems pretty high so I wanted to get some advice before moving forward. PLEASE HELP!!!!
Old Jul 26, 2004 | 09:31 AM
94van's Avatar
94van
How did they determine you need an evaporator? Did they use a sniffer?
Personally, I would stay away from the chain shops and find an A/C specialty shop.
Old Jul 26, 2004 | 07:43 PM
Inthesunshinestate
Thanks I will do that. I am not sure if they used a sniffer or not. That is what they explained to me but they did add 1 lb of freon and it has been blowing very cold air since so if I have that problem again I will go to an a/c specialty shop.
Old Jul 26, 2004 | 08:46 PM
Pikachu's Avatar
Pikachu
Over what period of time did this cold to hot transition occur?
Old Jul 26, 2004 | 09:32 PM
Inthesunshinestate
Last summer it was fine. Then over the last 3 months it began to change.
Old Jul 26, 2004 | 10:48 PM
Pikachu's Avatar
Pikachu
It could certainly be a leak. If/when it starts to get warm again, I second the motion to let a specialty shop find the leak, and go from there.
