Taking dash apart
Old Jul 26, 2004 | 03:31 AM
jhobbs26's Avatar
jhobbs26
Taking dash apart
I've got one of them annoying squeeks on the driver side dash of my '97 EB expy. I plan on taking the dash apart to hopefully find the squeek and want to know how big a pain in the **** is it?
Old Jul 26, 2004 | 11:55 AM
ExpyBoy's Avatar
ExpyBoy
Look around the Dash Bezel.... Those are pop-in pieces... it's probably there that the squeek is happening
Old Jul 26, 2004 | 12:37 PM
HomerWinzlow's Avatar
HomerWinzlow
Is the squeek to the right of the steering columb? I have had a few in the past that had a screw that was not all the way in under the panel below the columb that was pretty common. It will annoy you pretty bad. If you take the piece off around the cluster there is a screw behind the headlamp switch. You will have to remove the switch to get to it. Other than that most of the screws are in view as you go.
