302 power problems
Old Jul 25, 2004 | 11:43 PM
traderguy111's Avatar
traderguy111
302 power problems
I have a 89 bronco with a 302. Its been rebuild about 10,000 miles ago, I am just about ready to get rid of it This thing has no!!!!! power. Are these engines a dog or what? I have changed the exhaust, ignition module, fuel injectors, fuel pump and filter, plugs cap rotor, timing. Everything I can think of to get more power out of this thing. I pull a 18 foot trailer and I can hardley get out of my own way. Does anybody have any Ideas or should I be looking for a new truck? Thanks Dan
Old Jul 26, 2004 | 09:01 AM
EgoMan's Avatar
EgoMan
302 isnt exactly a good towing motor....Its just not torquey enough, IMHO.
put it in a large vehicle and its just gonna be slow, and if your running larger tires than stock thats gonna hurt you too. If the motor is stock its probbobly not gonna get much better without mods.
Old Jul 26, 2004 | 10:47 AM
Kemicalburns's Avatar
Kemicalburns
what size tires are you running. might look into getting a gear swap to 4.10's this will help in the towing department. headers, edelbrock efi truck intake, aluminum heads, cam and larger throttle body will help alot to. Or sell that motor and swap over to a 351w and be in good shape.
late
Old Jul 26, 2004 | 11:15 AM
EgoMan's Avatar
EgoMan
Yep Thats what im talkin about. Without adding some power to that engine you could do just as good if not better with a strait 6 and some gears, and get great fuel economy. but i think it needs gears.
Old Jul 26, 2004 | 11:35 AM
traderguy111
Im running 31x1050 tires, its got 410 gearing know. How difficult would it be to switch to a 351? Would I have to change the computer and all that?
Old Jul 26, 2004 | 12:21 PM
Kemicalburns
with a complete 351w all you would change is the ecu (very easy) and the flexplate as well. you would use your 302 harness on the 351 and away you go. it took me a weekend to pull 302 and a weekend to install 351 . really easy i thought and i am an average mechanical skill
Old Jul 26, 2004 | 12:23 PM
Kemicalburns
also , are you sure about the gearing. because stock is 3.55 in most unless you had already changed them over . check the tag on the rear axle just to be sure.
Old Jul 26, 2004 | 12:33 PM
traderguy111
I will check the tag, Thanks. Did you do anything different to the 351 when you put it in? Did you notice any differance? What kind of 351 did you put in? (windsor,clevland)?
I know these are a lot of questions but I really dont want to go through the work if there is not much differance. Thanks Dan
Old Jul 26, 2004 | 12:42 PM
Kemicalburns
its almost night and day difference. i also gained some mpg on the hwy to. I got 12/14 with the 302 and i now get 12/16 with the 351. I didnt do anything to the motor its stock but low miles. got a used one from the wrecking yard. the windsor is the only 351 you can install in there. just and fyi, the 302 puts out 220 ftlbs of tq and the 351w puts out 310. and has much more potental to.
late
Old Jul 26, 2004 | 03:07 PM
95 F150's Avatar
95 F150
I thought the 302 put out 275 lb/ft of torque, 220 seems a little light.
Old Jul 26, 2004 | 03:53 PM
Kemicalburns
yea your right.
Old Jul 26, 2004 | 05:10 PM
AYoungblood's Avatar
AYoungblood
180 hps and 270 torque.
IMO the 302 has MUCH more potiental because its the mustang motor so there are a ton of mods.
Adam
Old Jul 26, 2004 | 05:30 PM
Kemicalburns
Adam
that motor has lots of potential ( in a mustang) but not in a 6000 lb truck. also with the majority of these trucks/broncos being speed density that really limits what can be done to the motor. Thats why a 351w swap would be a better start because in stock form it performs better then with a few minor mods it really comes alive.
Old Jul 26, 2004 | 09:36 PM
EgoMan's Avatar
EgoMan
I guess you could use whatever the lightning uses for intake and other power adders aswell.
Old Jul 27, 2004 | 09:10 AM
Kemicalburns
yes you could use the gt40 intake which produces some good torque, but as for forced induction they run a tweecer system that is spendy to aquire but allows for a person to keep the speed density system.
