Reprogramming Door locks?
The owner manual only gives the procedure if you have the keypad in the door but I don't have that option.
Also is there an easy way to keep the dome lights from comming on when the doors are opened?
Thanks
Jeff in ND
Here is what the shop mnaual says...........
1. Close all doors.
2. Confirm that the ignition switch is in the OFF position.
NOTE: Steps 4 through 8 must be carried out within 30 seconds.
3. Turn the ignition switch from OFF to RUN.
4. Press the power door lock UNLOCK button three times.
5. Turn the ignition switch from RUN to OFF.
6. Press the power door lock UNLOCK button three times.
7. Turn the ignition switch from OFF to RUN.
8. Verify that the horn chirps. This indicates the enable/disable mode and now is ready to accept program changes.
9. Press the power door lock UNLOCK button one time to command the module to toggle the autolock/relock feature OFF.
10. Press the power door lock LOCK button once to enter the command.
11. Verify that the horn chirps one time. There should only be one chirp indicating that autolock/relock feature has been disabled. If one chirp is heard, followed by a longer sound of the horn, the autolock/relock feature has just been enabled. Return to Step 10.
12. Turn the ignition switch to the OFF position to exit the enable/disable mode.
13. Exit the vehicle and verify that the horn chirps once to indicate that a feature has been changed and that autolock/relock has been disabled.
