Offroad & 4x4
Will they fit?
Old Jul 25, 2004 | 07:44 PM
firefighter23114's Avatar
firefighter23114
Will they fit?
Will a 1977 ford 9" rear end fit under my 1990 F-150 with a 8.8 rear end with no modifications? The 77 has 4.11 gears w/ a detroit locker, and i know my front gears would have to be changed.
Also what would have to be done to get the 77's strait axel to fit under the front of my truck that currently has I.F.S.?? how much trouble would that be?
Old Jul 25, 2004 | 08:50 PM
Jack01's Avatar
Jack01
you should have twin I beam under the front if it is not a 4x4. and the rear diff should fit the frame on most Ford trucks from the 70s to late 90s is the same. measure the track and see if it is the same ..that would be from hub to hub
Old Jul 25, 2004 | 09:06 PM
firefighter23114
It is a 4x4 with 4" susp. 33" tires 351W and 3.55 gears currently
