Steel reinforced epoxy putty
I use JB Weld, that stuff is GREAT. Matter a fact, I just used it this afternoon. I had to put some new piecies of exhaust on my car and there were a couple of spots i couldnt reach with the welder so i just used the JB Weld to fill in the holes. You have to let it set for about 12 hours or so, if you can apply so heat to it, it will dry much quicker. You can use it on anything metal, I put a crack in my aluminum oil pan a while back, just drained the oil filled the crack up with that JB Weld from the outside of the pan. Next day filled it back up with oil and has never leaked since.
It doesnt hold up to really HIGH heat though, i have a crack on my exhaust manifold on our 95 bronco so to put it to the test I tryed it on that, didnt work though. It just kind of baked off.
(JB WELD, SOME GREAT STUFF )
Blackwaterforge
11-21-2012 08:55 AM
51phil
09-21-2010 12:08 AM
reed1951
33
11-30-2007 07:09 PM
