AMP mounting location
Old Jul 25, 2004 | 12:37 PM
Flippinstk's Avatar
Flippinstk
Question AMP mounting location
I already posted this on the sound system forum, but I figured I'd also post it here.
I need some help finding a mounting location for a Sony Explod 600 watt amp.
I have a 03 Expedition, and with the folding down seats that also lower after the are folder it cant fit under the seats. The area where the jack is all the way in the rear also has a very shallow area and it cant be mounted there. I had the left side (right next to the back seat, dont know what its called) open but there is no ventilation for the unit to breathe. I was wondering if anyone as installed a big unit like this in a Expy and where they installed it.
Thanks for the help!
Alex
Old Jul 26, 2004 | 12:43 AM
fst96se's Avatar
fst96se
I need info on the same thing, but for a 2000 EB with third row, and I have TWO big amps. Someone give us some ideas!
Old Jul 26, 2004 | 12:23 PM
BlckExpo02's Avatar
BlckExpo02
How big is your box? Is it possible to mount it directly to the back of the box?
Old Jul 26, 2004 | 12:41 PM
Flippinstk's Avatar
Flippinstk
the amp is 11 1/2 x 16 1/2
Old Aug 23, 2004 | 08:17 PM
expeditionary's Avatar
expeditionary
I have a 2001 exp and I have a 600 watt kenwood in which I installed underneath my front passenger seat and ran the wires under the carpet. Worked fine. The only small thing is that the handle that moves the seat back and forth hits it a little. other than that it is perfect. I even have the area where I do my adjustments facing the open window facing the door. Sweet
Old Aug 23, 2004 | 08:39 PM
Justwingem's Avatar
Justwingem
I have 2 Audiobahn Amps mounted to the rear gate. One running 4 Infinity Kappa's and the other 2 JL Audio 10's. Running the wiring was a little tricky but never the less works verry well. The floor airvents were in the way for under the seat mounting in mine.
