Np 208
Old Jul 24, 2004 | 03:51 PM
DT 466Man's Avatar
DT 466Man
Np 208
is it a part time 4wd system or full time?
what is the shift pattern?
Old Jul 24, 2004 | 04:45 PM
Jimbare's Avatar
Jimbare
all alone in the world
do you mean the warner 208, or new process 203. both can go either way. one is aluminum case, the other is caststeel.
jim
Old Jul 24, 2004 | 04:47 PM
DT 466Man's Avatar
DT 466Man
i saw 208 on a round tag on the back of the transfer case
can the linkage to the shifter on the transfer case be adjusted?
Old Jul 24, 2004 | 07:05 PM
bremen242's Avatar
bremen242
The 208 in my '85 starts on the floor with 2HI-4HI-NEUTRAL-4LO when you pull it the whole way back. I'm pretty sure that there is no adjustment for the NP208. If you are having problems shifting, it is probably the shift forks going bad.
Old Jul 24, 2004 | 07:31 PM
DT 466Man's Avatar
DT 466Man
probally because all the way forward the axle is engaged but all the way towards the seat it is not so i know i have 4wd but not in the right places on the shifter
Old Jul 24, 2004 | 09:34 PM
Jimbare's Avatar
Jimbare
check the rubber bushings on the shift rod for wear.
jim
Old Jul 24, 2004 | 10:07 PM
82F100SWB's Avatar
82F100SWB
Hmm, I had that problem when I put my buddys truck back together for him once, but, I have no sweet clue what I put in wrong to make the shift pattern backwards...
Old Jul 25, 2004 | 09:16 AM
bremen242's Avatar
bremen242
I was just thinking that something was backwards... It is probably the lever on the tcase that is reversed...
Old Jul 25, 2004 | 09:20 AM
DT 466Man's Avatar
DT 466Man
ok i'll check that
thanks
Old Jul 25, 2004 | 09:56 AM
Jimbare's Avatar
Jimbare
it could also have the wrong shift rod on it. there are 4 different lengths. try takeing the shift rod off the t case and shifting it from underneath. that way you will know if it is the t case or the shift mech.
jim
Old Jul 25, 2004 | 12:54 PM
DT 466Man's Avatar
DT 466Man
ok where would i get another shift rod if i needed it?
Old Jul 25, 2004 | 01:08 PM
Jimbare's Avatar
Jimbare
i just spliced into mine and lengthend it a little when i couldnt find the right one. you could also shorten 1 by cutting and rewlding.
jim
Old Jul 25, 2004 | 01:40 PM
DT 466Man's Avatar
DT 466Man
ya i guess that would work
when i put the lever all the way to the dash it is kind of in Neutral but grinds a little why would it do that?
Old Jul 26, 2004 | 02:48 PM
TallGuy_Az's Avatar
TallGuy_Az
What is the shift pattern on the ****?
Old Jul 26, 2004 | 06:37 PM
DT 466Man's Avatar
DT 466Man
it's not from the truck it's from a dodge
it is
dash
2hi
4hi
N
4lo
