C6 compared to AOD
Old Jul 24, 2004 | 11:08 AM
1979f_100's Avatar
1979f_100
C6 compared to AOD
My truck has a stock 351M (121500 miles) C6 trans and 2.10 gears in a Dana 44(?). I want to drop the gears to around 3.50-3.73 and I am considering an AOD trans. What are the gear ratios in an AOD compared to a C6 and would one bolt up to a 351 M. If so, what adaptors do I need and where would I get them if I need them.
Old Jul 24, 2004 | 01:22 PM
ecarter50's Avatar
ecarter50
AOD is only available with 300/302/351w bellhousing pattern. Tech article tells how to adapt to 351m/400.
Old Jul 24, 2004 | 02:53 PM
1979f_100's Avatar
1979f_100
Thanks that's really helpful.
Old Jul 25, 2004 | 01:16 PM
SoCalDesertRider's Avatar
SoCalDesertRider
manual AOD ratios: 1st: 2.40, 2nd: 1.47, 3rd: 1.00, OD: 0.67
AODE/4R70W ratios are different from the manual operated AOD.
