Throttle body replacement.....
Old Jul 24, 2004 | 10:46 AM
LinearPower's Avatar
LinearPower
I have an accelerator that is very difficult to use at times. Very stiff is the best way to describe it. I'm talking "stomp on it to get it to work" stiff. I was told by an experienced Ford technician that the only way to solve this is by replacing the throttle body. Any input from others who have had this problem or know the solution??? Thanks.
Old Jul 25, 2004 | 06:11 PM
LxMan1's Avatar
LxMan1
It could be worn and binding up , but I would first remove it and inspect it. You may be able to clean some build up out of the shaft bushings and free it up. It may be closing too far if simeone has tried to adjust it and it is closing too tight and binding up.
You may also want to check the cable (unhook it from the TB and see how smooth it is). If it is coming apart internally, ti will cause the same symptoms.
Jimmy
Old Jul 26, 2004 | 06:38 PM
LinearPower
Jimmy, Thanks for the advice. Since I would not be changing the TB for performance reasons, what you recommend sounds like what I'm looking for.
Greg
Old Jul 27, 2004 | 11:07 PM
LxMan1's Avatar
LxMan1
MAC has a nice one. 75mm. It would probably be cheaper than a new stock one.
