Need 6.0 advise
Need 6.0 advise
Vehicle Background - F-350, 6.0; MFG 03/03. The truck has been flashed 3x and I'm told is current. A new injector was installed a few months ago and the cam positioning sensor has been replaced. The vehicle has 30K on it and is used dilay to tow a work trailer @ approx 4K
Current dilema:
Intermittent check engine light - Vehicle sounds muffled just prior to the engine light coming on. Conditon usually lasts 1-2 days and then the light goes out. This conition has been repeated several times over the past few months.
Frequently, but not consistently, the idle on the vehicle drops dramatically. Often times at a traffic light it sounds as if the truck has shut off. Only after hitting the accelorator does the normal "diesel" sound return?
Also.... What I'm told is "turbo wash" seems to come and go with no distinct pattern.
On the advise of a mechanic, I unplugged the lead going to the filter minder and nave not experienced any check engine lights in tha past few weeks. The idle and turbo issues, however, still remain.
I'm loyal but am losing patience. This next trip will make 9 in the past year. I'm confident in my service dep't but can sense their frustration as well. I would appreciate any feedback that I can provide to them to help with these issues.
Current dilema:
WHAT ? --- unplugging the filterminder corrected your problem ?!!!
That is a new one I've NEVER heard of --- someones getting REAL creative here
And does the 6-oh HAVE a Cam Positining Sensor - I thought that was just in the 7.3?
I would not be confident at ALL in my mechanic - I'd RUN to where a certified 6-oh diesel mechanic is !
If your surgeon took nine tries to get your heart valve fixed would you be confident in him ??????????????????????
Response
I'm not a car guy so I have no idea waht parts are different between the 7.3 and 6.0 . I just have a service ticket showing replacement of the camshaft poistioning sensor.
Also...on a recent visit to my dealer the air flow sensor showed up a problem code but none were in stock. The suggestion to unplug was our attempt to further isolate the problem. Might not have been a good idea but I'm trying!
I appreciate the input. I'm new to the site, and find it both profesionally done and extremely informative.
A couple of questions though:
Do my current problems seem routine for an early 03? My dealer seems to fix each issue that arises but new problems seem to come up.
Are there any specific remedies that I can recommend?
I've read alot recently about the aftermarket "chips" such as the predator. Since the system re-flashes the computer could it help to solve my re-occurring issues?
