I am looking for a manufacturer that just produces leaf spring lifts, because I am looking for something custom. I have an 89 F-350 single cab 7.3 4x4. I want to get a six inch spring lift for the rear (So I can eliminate those 3in blocks in the rear) and a four inch for the front. I can make up the difference in shackles and make my own drop downs for my stearing I just dont know anyone that will sell straight out springs. Any input, criticizm, comments, or ideas will be noted.In other words thanks!
National Spring makes custom leaf packs. Check your local yellow pages, you may be able to find a spring company in your area that can put something together for you.
When I first lifted my truck I went with rear blocks and later decided on rear springs. I went with skyjacker spings. I also found that pro-comp sells springs for my truck. Said they were for f250/F350 1980-1998. I found the skyjacker ones on their website and the pro-comp ones at summit.
Can't remember skyjackers website but I remember that I couldn't order through it. I had to go thru an authorized dealer so I had the guy I ordered my lift kit from order them. You can find the pro-comp ones at summitracing.com and I think the ones you want are gonna be EXP-23411 for the rear and I can't remember # the front because I already had some. I was gonna buy these but decided to stick with skyjacker all the way around. I'm pretty sure they will probably have the skyjacker ones at summit too. Hope this helps.
