Aerostar Ford Aerostar
Freeze plugs
Old Jul 24, 2004 | 10:41 AM
bear2x2's Avatar
bear2x2
I replaced my modulator valve and it worked great for a couple of weeks then the up shifting started messing up again. I looked at the valve and saw that the hose had expanded a littlefrom when it was sucking up tranny fluid from the bad modulator. I put a small hose clamp on it to hold it on..problem solved. I do not know if you know were the modulator is but its on the passanger side of the trans mition. Just lay down on the ground on the passanger side and you should see a small hose going to the transmition.
Old Jul 24, 2004 | 10:45 AM
Lila's Avatar
Lila
I will check this out. thanks
bluegrass65
16
Dec 27, 2025 05:05 PM
handymanken
Sep 7, 2010 10:02 AM
cyberdr2
1978 - 1996 Big Bronco
May 21, 2010 03:59 AM
MarkMoore
Modular V10 (6.8l)
27
Feb 21, 2007 06:36 PM
NJ239Y
Sep 10, 2005 02:22 PM
