-10mpg 04 Screw Lariat 4x4 5.4
Old 07-23-2004, 04:53 PM
robinwood's Avatar
robinwood
robinwood is offline
I have a '04 Supercrew Lariat 4x4 with a 5.4 (2,700 miles) and im getting just under 300 miles a tank (30 gallon tank). Not only that, the gauge and computer thing in the dash arent correct. I was driving the truck last week and the computer said I had 0 miles left and I had only driven 245 miles on the tank. So I filled up a gas can, bungy corded it in the back and drove it until she ran out of gas at 289 miles! I've taken the truck to ford 4 times now and first they told me the truck needed to break in, then they supposedly did a mileage test with a computer and said it came back with 13 miles to the gallon. I told them they're results were wrong because im doing the math and I know what its getting. If I cant get this resolved, I might be looking at lemon law. I love the truck other than the mileage, but 8-9 miles to the gallon is unacceptable. I have 2 friends with the same truck. One is a supercrew xlt 2x2 5.4 and the other is a fx4 4X4 with 5.4 and both dont even get a low fuel light until 380 miles which means probably 430 miles to the tank. I could only wish
Old 07-23-2004, 05:50 PM
fatman66's Avatar
fatman66
fatman66 is offline
I thought that it was either a 26 gallon tank or something like 37 gallons for the big one on the 04's?
Old 07-23-2004, 06:07 PM
robinwood's Avatar
robinwood
I know the supercrew is 30 gallon. I think the supercab is like 26 or something. I would look it up in my manual but its in my truck and the truck is at the dealer hopefully getting fixed.
Old 07-23-2004, 06:37 PM
jzarwell's Avatar
jzarwell
jzarwell is offline
I am pretty sure my supercrew has a 25 gallon tank, I filled up this morning when the low fuel warning was on, the total was just under $42.00, and the price of the gas was something like $1.92 per gallon. I averaged about 15.8 mpg on a 450 mile trip today.
Old 07-23-2004, 07:55 PM
vaughn1's Avatar
vaughn1
vaughn1 is offline
Based on what I have read, I'd say you were being shorted 4 to 6 MPG.......
Old 07-23-2004, 08:04 PM
Banshee rider's Avatar
Banshee rider
Banshee rider is offline
I have the 4.6 and get around 16-18 mpg. The 5.4 shouldn't get that much worse unless you are towing, carrying heavy weight, or climbing steep hills. Even a lifted truck will probably only lose 3-5 mpg. I'd say you are getting s-crew'd
Old 07-23-2004, 09:04 PM
fatman66's Avatar
fatman66
fatman66 is offline
I went to check the specs on the ford web site but the link leading to the 04 specs is dead and redirects somewhere else, damn I was curious if the Screw had a bigger tank than the Scab. I have an XLT 04 Scab 4x4 w/ 5.4 and I get less than 300mile/tank and I know I have the 26 gallon.
Old 07-23-2004, 10:20 PM
blitzen25bm's Avatar
blitzen25bm
blitzen25bm is offline
got the 30 gal in my supercrew and im getting 10.2 :P hahah. used to worry me but who cares im paying for premium in all the other cars.
oh yea and it says 30 gallon fuel tank under standard equipment on my window sticker.
Old 07-23-2004, 10:23 PM
myfordf350's Avatar
myfordf350
myfordf350 is offline
Sounds like you GOT SUPER SCREWED !!!!!!
Ford will buy your truck back
Old 07-23-2004, 10:30 PM
fatman66's Avatar
fatman66
fatman66 is offline
I think you have to go to through the DSB before the lemon law procedure. 8-9 mpg is ridiculous, even that gas guzzling Dodge does better than that. If that mpg test they did was computerized then I say its crap, I know you said that the math (best way to figure it) says 8-9 but since you have the lariat, what does your message center tell you for mpg? Call the dealer and say that you want this resolved or you go to the DSB, if you had it in four times for this then I think you have ample evidence.
Old 07-24-2004, 02:45 AM
robinwood's Avatar
robinwood
The message center stays 11.1 pretty much all of the time. I dont trust it at all though. Last week I let it go to zero and still drove another 45 more miles. When I fill up it says i have around 350 miles left, but I never really get over 300. Whats the DSB? and how do I start the lemon law process without having to get an attorney? Do they give me a new truck or how does that work? I didnt put any money down on it, but I have made 2 car payments. Thanks for everybodys input.
Old 07-24-2004, 05:45 AM
hovy's Avatar
hovy
hovy is offline
I hear you robinwood and I agree that your figures are low but you need to put a few more miles on it. Ford fees that a motor under 10,000 miles is still not broken in.
I don't understand the big tado over mileage. It is what it is a truck that is first made to "work" and second made to get the groceries! When I go and hookup my cargo trailer I don't even think about mileage, I want power and safety first hauling 8600 lbs first. I played that annoying game of watching the mileage and driving in a way to get the most. I realized that I wasn't driving like a liked to and enjoying the truck less....It is a nice truck but that what it is...You want gas mileage buy a rice maker.
Old 07-24-2004, 08:14 AM
Hokie4tec's Avatar
Hokie4tec
Hokie4tec is offline
5.4L SuperCrew 4x4 with 850 miles. 50/50 highway city. Towing 1100 lb. Jetski on the weekends. 11.6 mpg. Fuel computer and hand calculation match closely. I have a 30 gallon tank. The howl the intake makes at 2500 rpm is worth the price of lower mileage.
FYI be careful running the tank dry. Everybody I've talked to has lost their fuel pump within weeks of running out of gas. It burns up when it runs dry.
If you're getting 8-9 mpg, and there are no trouble codes, you may have a vacuum leak. If that's the case, the computer is richening the fuel mixture to compensate for the excess oxygen in the intake. Dealer needs to hook up to the computer and check the fuel trim to see if it's in range. On my old clunker, I'd check for vacuum leaks by spraying starting fluid around the hoses. If the idle speed changed, there was my vacuum leak. Wouldn't recommend it on these new vehicles.
Good luck.
Old 07-24-2004, 02:10 PM
fatman66's Avatar
fatman66
fatman66 is offline
Normally I would agree but even with a truck like this with lots of power there are still realistic milage expectations and 8-9mpg is way too low, I mean they advertise 14 city on the sticker, if you get 8 mpg, that is only 57% of what they claim, too much error to be normal. I feel 10-12 (no towing) is on the low side but acceptable, I consistently get 13.5 around town, 16 on the highway (Scab 4x4 5.4). The DSB is the dispute settlement board, it exists to settle disputes between FoMoCo and owners with problem vehicles. There should be information about the DSB in your manual. I don't think you need a lawyer for the DSB just all the documentation about your vehicles problems.
Old 07-26-2004, 10:03 PM
pwrlineman's Avatar
pwrlineman
pwrlineman is offline
I have same truck/ 30 gal tank 12,000mi. at 2700 I was recording around 14mpg. 24 gal. of 89 took me 354mi. Fuel mileage didn't level off untill after 2nd oil change at 6000 mi. My local travel yelds average mileage around 14.5- 15mpg, with my last non-tow trip producing 18mpg (319mi-17.7gal). I reset my mpg display with every fill-up and it is usually within .5mpg of my accual caluculations. Variations only come when the tanks end usage is dramatically different than the first portion.
Quick Reply: -10mpg 04 Screw Lariat 4x4 5.4
