95 Exploder Driver Pwr Window
Old Jul 22, 2004 | 05:50 PM
stubborne's Avatar
stubborne
Driver pwr window started working intermittently (only quit in the down position). Now it's completely dead (in the down position). Figured it's probably the motor and wanted to know my options. I have the panel off but don't see much room to work, can't identify the motor. Any help here on the position would be nice, also any steps on replacement. Also, is there a way to manually work the window to the closed position? It's supposed to rain tomorrow. Thx in advance...
S-
still going at 140K+
Old Aug 1, 2004 | 02:47 PM
chrisbeery's Avatar
chrisbeery
get some electrical spray cleaner and hose down your switches. slide a putty knife between the door panel and the switch plate on each side and pull the switch panel off. you can then pull each switch off the panel and clean the contacts. works most times.
Super Duty Daddy
Electrical Systems/Wiring
Oct 7, 2013 08:27 PM
kyledallas
19
Jan 3, 2012 04:42 PM
Explorer Freak
Jul 25, 2010 10:33 PM
361 ranger
1983 - 2012 Ranger & B-Series
Jul 6, 2007 06:44 AM
SHADOWGRAY03
Jun 1, 2007 08:47 AM
