Engine experts
Old Jul 22, 2004 | 07:07 AM
powerstroker250's Avatar
powerstroker250
Engine experts
The engine idles rough and shakes the truck to about 1300 rpm. 3500 miles on the oil and full, 5k on cps and 8k on fuel filter. No unusual smoke or EGT. No chip or programmer either. Any ideas?
Thanks, Les
Old Jul 22, 2004 | 01:39 PM
basstardo's Avatar
basstardo
Bad batch of diesel fuel maybe...
Terry
Old Jul 22, 2004 | 04:45 PM
BCS_tx_dieselman's Avatar
BCS_tx_dieselman
Question Shaking
What year model? Is it standard or automatic?
Old Jul 22, 2004 | 06:28 PM
01stroker's Avatar
01stroker
Could possibly be the infamous dual mass flywheel.
Steve
Old Jul 23, 2004 | 06:31 AM
powerstroker250
It's a 99 PSD, no dmfw. I don't think it is the fuel. It started when I had a 1/4 tank and then I refueled at a different station the same day.
Old Jul 23, 2004 | 10:47 AM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
The first thing on the list in the service manual is to check for aerated oil. Do you have a means to check the HPOP pressure or voltage?
Old Jul 24, 2004 | 06:33 AM
powerstroker250
No I don't. What voltage are you talking about?
Old Jul 24, 2004 | 01:57 PM
International Tech's Avatar
International Tech
take the strainer off and check for debris or any contamination.He probably is talking about ICP voltage or IPR voltage. If you had a good scan tool u may can get the ICP readings from it.
Old Jul 24, 2004 | 04:07 PM
powerstroker250
Drained fuel bowl and replaced the filter, looked almost new after 8k. Super lopey until I get past 1300 rpm. After 1300 rpm it seems to run strong. Valve cover connections look good
Old Jul 24, 2004 | 10:11 PM
cookie88's Avatar
cookie88
FTE Emeritus
Yep, I was talking about the ICP voltage, but I'm thinking now that it won't be neccessary to actually measure the pressure.
First change the oil to rule out an aeration problem.
If that doesn't fix it then try disconnecting the ICP sensor, if the idle smoothes out the ICP signal is at fault, if not, you may have some debris stuck in the IPR.
Old Jul 25, 2004 | 08:05 AM
powerstroker250
Is the ICP sensor the one on the left head or on the hpop?
Old Jul 25, 2004 | 10:03 AM
powerstroker250
Do I unplug it with the engine running?
Old Jul 25, 2004 | 12:08 PM
powerstroker250
Oil changed with no difference. Disconnected the ICP with no change. The only thing that happened was I got the SES light. I see 3 sensors on the hpop, 1 on top, 1 on the upper leftside and 1 on the lower leftside. What are they?
Thanks, Les
Old Jul 26, 2004 | 02:22 PM
LuLuGoin2ADiesel's Avatar
LuLuGoin2ADiesel
I'm not sure PS250, but I'll bounce this back to the top of the list for ya.....
Old Jul 26, 2004 | 09:29 PM
cookie88's Avatar
cookie88
FTE Emeritus
Thanks, Les
The upper left is the engine oil temp, the lower left is the electrical connector for the IPR valve, and on top to the right is engine oil pressure.
When you unplugged the ICP (drivers head) with the engine running you made the PCM default to a set oil pressure. Since the idle didn't change the ICP is working.
