1978 - 1996 Big Bronco
sub woofers
Old Jul 21, 2004 | 01:46 PM
rockinkcollins's Avatar
rockinkcollins
sub woofers
ok, i am putting in 2 12 inch polk momo subs in a box i am building (wedge hatch style) in the back of my 95 bronco. the angle of the subs is the same as the rear glass. i have 2 profile amps. one for the subs and one for the polk 6.5's and 5x7's. (the head is an alpine). so my question is where do i mount the amps? the box ideally would be right up against the back seat (firing backward). the box isnt big enough to fit the amps on the sides(wedges). should i build some larger side plate things to mount on the side of the box, or is there room on the back of the box? i would like to have the amps hidden, but wont the overheat behind the box? HELP ME!!!
Old Jul 21, 2004 | 02:08 PM
mustangman65_79's Avatar
mustangman65_79
I couldn't hide mine, so i mounted it on top of the box, the cooling fan never comes on cuase it runs so cool
Old Jul 21, 2004 | 03:10 PM
ChargerFan's Avatar
ChargerFan
My amp is in the console along with the cd changer. I need to figure out where to mount two 8" Bazooka tubes. Any ideas?
Old Jul 21, 2004 | 04:22 PM
rockinkcollins
for the tubes maybe on the rear top? as to the amps on top, im not sure if they will fit. my box needs to be as close to .88 cubic feet as possible.
Old Jul 21, 2004 | 06:59 PM
bronco5.8's Avatar
bronco5.8
There's a space underneath the rear seat, measure the height of your amps to see if it'll fit. I have two rockford fosgate amps underneath the rear seat and have no problem with the heat.
Warr
Old Jul 21, 2004 | 07:30 PM
dyarumian's Avatar
dyarumian
I fit a 500 Watt amp under the front seat just fine, But i have a front bench so i dont know how much room the majority of you guys have
Old Jul 21, 2004 | 08:30 PM
rockinkcollins
ill try that
