need some help
Old Jul 21, 2004 | 10:31 AM
824x4ride's Avatar
824x4ride
need some help
well the motor build is pretty much complete for now on the ole' 72 now iam in the final stages and just adding pretty stuff now and my question is can someone tell me were to hook up my oil pressure guage on the 360? there isnt a factory sender and i cant find a spot, maybe my headers are just in the way or iam just not looking hard enough. but any and all help is much appreciated.....thanks again
-kyle
Old Jul 21, 2004 | 11:50 AM
Mike G's Avatar
Mike G
The sending unit "should" be mounted to the oil filter adapter (aluminum part from the motor to the filter). They have the one-wire type post on the top that the guage wire hooks to. Unless of course you have converted to an actual "pressure" type guage, for which you will need to plumb an oil line from the sender to the guage.
--Mike
Old Jul 23, 2004 | 11:19 AM
824x4ride's Avatar
824x4ride
thanks mike i wasnt quite for sure about that sender but i will be running an acual pressure guage so ill plumb the line and go from there....thanks again!
