Sponsored by: Real Truck
Gear recomendations???
Old Jul 23, 2004 | 06:07 PM
DougD's Avatar
DougD
Originally Posted by TOPFLOR
that is gonna be bad..gears are on my wish list
Siyé
I was told that if I didn't get the gears that it may damage my tranny - so seemed the "sensible" thing to do...
Old Jul 23, 2004 | 09:03 PM
JCROMAN's Avatar
JCROMAN
Originally Posted by SoCalDesertRider
265/75-16's are approx. 31.5" tall.
Using the formula: -------- NewGearRatio = (NewTireDia / OldTireDia) X OldGearRatio ------,
We can find the effect of different gear ratios and tire sizes and how they compare performance-wise with the stock ratio and stock size tires.
37 / 31.5 x 3.73 = 4.38. So 4.30's will get the effective ratio back to the stock 3.73 ratio.
For a 4.10 effective ratio, just plug in 4.10 for 3.73 in the same equation: 37 / 31.5 x 4.10 = 4.82. So 4.88's would be similar to a 4.10 ratio with stock tires.
If we plug in 3.90 for 3.73 in the equation: 37 / 31.5 x 3.90 = 4.58. So 4.56's would be similar to stock tires with a 3.90 ratio.
By the way, I run 4.56's with 33's on my gas-powered F350, for an approx 4.30 effective ratio .
well actually a 37 inch radial only measures 36 and a the stock tires only measure about 31. so 36/31x3.73=4.33 so 4.30's would get you back to stock gearing. if you had 4.10's stock 36/31x4.10=4.76 so 4.56's would be a good inbeetween gearing. thats what i run with my 37's and it works out nice. mileage is exactly the same and i have alot more power.
jamie
lcf250
May 29, 2014 06:27 PM
BACKWOODS99
Jun 22, 2011 02:32 AM
shanksyamaha
Modular V10 (6.8l)
33
Aug 4, 2009 12:15 PM
trackdayhauler
Modular V10 (6.8l)
16
Jan 25, 2009 07:36 PM
Fordman7780
Offroad & 4x4
Sep 25, 2002 05:22 PM
