slip/clunk update on acceleration
Old 07-24-2005, 09:07 PM
ReForder's Avatar
ReForder
ReForder is offline
I get a slight shudder in the rear (3.72 LS) on acceleration from a dead stop, all i've noticed so far.
it frightens me what these service dept.'s come up with...airbags? leaf spring bushings? with all the TSB's and documentation regarding the driveshaft and LS axle problems, why won't they address those concerns or rule them out first, then start making up wacky service orders at their own leisure. The old "have to see the forest before the trees" thingy.
  #137
Old 11-19-2005, 08:31 AM
Inzax's Avatar
Inzax
Inzax is offline
Update.
Yes I know it has been awhile.
Dealer replaced my clutch packs. Dealer stated this was a limited slip issue and when the 2004's were produced they set them to tight. Packs were replaced and set properly. No more shudder on turns.
  #138
Old 12-05-2005, 04:46 PM
supergator's Avatar
supergator
supergator is offline
Wow, so much learned from this. I just bought a 04 Lariat SuperCab 4x4, 5.4L. It had 6000 miles on it when I bought it. I have noticed a slight slipping sensation and minor clunk. Also, have heard and felt the binding when in reverse. Vehicle gets about 13-14 miles per gallon. I'll be taking it to the shop with Ammo in hand from discussions on this board. Thanks guys.
SG
  #139
Old 12-05-2005, 08:49 PM
AllenB's Avatar
AllenB
AllenB is offline
I've got the NON-LS with a CLUNK,...NOT a shudder. Dealer lubed yoke and it fixed it for about 500 miles. Taking it in for second time. Not savy with the rear diff,..but are the clutch packs only on the LSDs??
Anyone had a "cure" for the NON LSDs?
Allen
  #140
Old 12-06-2005, 12:52 PM
supergator's Avatar
supergator
Also, went on to infotraxx and read the TSB's as printed for dealers. Saw what the recommended maintenance procedures were for the problem from FMC. It is nice to see the TSB numbers but it is much better to read them as they are for the service techs.
  #141
Old 12-15-2005, 02:01 AM
guerrero101's Avatar
guerrero101
guerrero101 is offline
My FX4 went into the shop for the third time today for the same clunking noise. I'll update you all when I get it back from the dealer.
  #142
Old 12-15-2005, 05:16 AM
PC Poppy's Avatar
PC Poppy
PC Poppy is offline
Has anybody had the slip yoke clunk repaired permanently? Greasing it every few months is a joke. Mine has been greased 4 or 5 times. Obviously there is a design flaw.
  #143
Old 12-15-2005, 05:33 AM
FS-150's Avatar
FS-150
FS-150 is offline
Would you mind posting the procedure for maintenance/fix for this problem as outlined on infotraxx?
  #144
Old 12-15-2005, 07:55 AM
supergator's Avatar
supergator
I would be violating their policy if I did that. They are also one of the site sponsors, I believe. So administration would probably frown on that also.
  #145
Old 12-15-2005, 08:23 AM
FS-150's Avatar
FS-150
FS-150 is offline
I realize that, I was just looking for a generalization. I am not looking to get you in trouble or anything .
  #146
Old 12-15-2005, 01:46 PM
CMOS's Avatar
CMOS
CMOS is offline
PC,
I've owned 3 Ford trucks over a span of 20 years and all 3 of them had that damn clunk. Grease it up, it's quite for about 2 months.
Yes, you would think Ford could fix this with a 20 year timeframe!
CMOS
  #147
Old 12-15-2005, 01:56 PM
PC Poppy's Avatar
PC Poppy
PC Poppy is offline
I feel like putting a zerk fitting on the housing and pump it full of grease like I did with my old 95 f-150. What a pain.
  #148
Old 12-15-2005, 10:11 PM
Draft_Horse's Avatar
Draft_Horse
Draft_Horse is offline
Originally Posted by txfx4x4
Lubing the slip yoke will cure a lot of these complaints. I don't know about all of them but it cured mine.
Where is the slip yoke?
I'm having the same problem but only in 4 x 4. In 2 wheel drive, there's no slip / clunk feeling or noise. In 4x4, feels like there's slipage and little clunks. All 8 U-joins are new. Had the transfer case open and looks minty. I figure if it's the clutches in the rear diff that it would do it in 2 wheel drive also but it doesn't. Is there clutches in the front diff? This is an '86 F250 4x4 dually.
  #149
Old 12-21-2005, 10:03 PM
guerrero101
I got my FX4 Screw back yesterday from the dealer. The dealer said the cause of the clunk was bad backlash, bad ring gear @FIFF (what ever that means). Correction: Rear axel housing assembly overhauled. So far everything sounds good, no more clunking on acceleration from dead stop.
  #150
Old 01-06-2006, 03:43 AM
Forrest_F150's Avatar
Forrest_F150
Forrest_F150 is offline
posted in this thread a few months ago with my clunk problems...
dealership was initially going to do the clutch pack thing (tsb).....
but they looked at it again and devided it was a u-joint that needed to be replaced and a few other things...
so they did this:
1) flashed my PCM up to the latest.....
2) greased slip-yoke......
3) replaced u-joint....
it's been about 8 or 9,000 miles later and the clunk has never returned, not event once......
Quick Reply: slip/clunk update on acceleration
