Mountaineer Thumping Sound
Old Jul 20, 2004 | 11:37 PM
Msp541's Avatar
Msp541
Exclamation Mountaineer Thumping Sound
Hey All! On my 1999 Mountaineer V-8 AWD i noticed a thumping sound when driving it sound like its coming from the left side, at a low speed i hear it well when i come to a complete stop its not making noise, i was thinking maybe the balljoints? Any ideas or has anyone run into this problem with their Mountaineer or Explorer? Hope someone can help..... Thanks!
Old Jul 21, 2004 | 06:11 AM
rblais's Avatar
rblais
Sounds like ball joints or possibly CV joints. I think worn CV's have more of a "clicking" sound though when in a turn. I just had the hub and bearing assemblies replaced on my 2000 Mountaineer (V8 AWD). The sound of the bearings failing was more of a pulsating hum while rolling. Very noticable at 45 mph. To me, a "thump" type sound means movement between metal parts (where there shouldn't be) muffled by rubber boots, bushings, grease or something like that. Worn control arm bushings or sway bar bushings might produce that kind of sound. Not likely though. Do you feel anything through the steering wheel or the break peddle? Is the steering OK? Get the wheel off the ground and check for play when rocking the tire in all directions. Have somebody look for movement at the ball joints (upper and lower) and other suspension and drive train parts. There was lots of play in the wheel of my truck and movement easily visible. It's a dirty job but someone has to do it! Like an expensive mechanic! Good luck.
Old Jul 21, 2004 | 09:08 AM
Backin72's Avatar
Backin72
Sounds a lot like radius arm bushings.
Old Jul 22, 2004 | 08:11 AM
Mountaineer40's Avatar
Mountaineer40
I have the same truck 98 Mount'eer...165k miles 5.0 liter. Inspect your tires well. I always have had a small thump noise on the front left side. Repair guys could not find anything wrong with joints, bearing, ..etc. But when I rotated tires..the noise disappeared. Try it out!!
M40.
Old Jul 22, 2004 | 08:43 AM
Msp541's Avatar
Msp541
Thanks Mountaineer i will try rotating the tires...
Brian
Old Jul 31, 2004 | 01:28 PM
Msp541's Avatar
Msp541
Hey Rablias;
Yeah i can feel the noise coming through the steering wheel when driving around 30-40 mph its not a humming sound its a thumping sound like you need shocks or something like that, i was wondering if it was the control arm bushings or ball joints. I havent checked the tire off the ground to see if there is any play with the tire but i will try that, any other suggestions?
Rays auto
Sep 6, 2016 10:49 PM
jayjjcc
Jun 27, 2012 11:26 PM
stonerboys
Mar 25, 2012 04:55 PM
CanadianSmokie
Jan 27, 2009 04:42 PM
tebby
Jun 17, 2008 11:21 AM
