Sponsored by: Auxito
service engine soon light
Old Jul 20, 2004 | 10:09 PM
TRIBBS's Avatar
TRIBBS
Cool service engine soon light
I have a 2000 ford f-150 with 4.6l. Service engine light went on today at first steady, wich made me think i had gotten some bad gas. While on interstate light began to flash so i took it to local part store that has hand held computer. Computer said nr 7 cylinder was not firing properly. Changed coil (not the best at newer vehicles) and plug. Light is still on and truck is still running very rough. Any ideas.
Old Jul 20, 2004 | 10:24 PM
mizzleman's Avatar
mizzleman
Try removing the negative battery cable for about 15 minutes to clear the computer. Hook it back up again and drive a few varied miles. The computer will "relearn" its operating parameters.
Old Jul 26, 2004 | 10:36 PM
coolk614724's Avatar
coolk614724
if youhave replaced the coil and plug then its probably a problem with your injector - try switching the injector with another cylinder and check your codes again. If the code if for the cylinder you put that injector in then you have a bed injector. I dont know how much those run but i would guess there not cheap
