few problems
Old Jul 20, 2004 | 12:27 PM
4xFordFreak's Avatar
4xFordFreak
few problems
I have a 1988 Ford F150 4x4 with a 5.0L. If the truck sits for more than 4 hours I have to cycle the ignition switch 3-4 times for it to start. I think it may be a fuel pressure problem. After the first start it starts fine but it does have to turn over afew times before it starts. After the truck warms up it idles higher and runs ruff. The truck has a new jasper engine in it with about 20K miles on it.I t also has 500 miles on new injectors idle bypass valve and TPS. Any and all help would be greatly appreciated ......... THANKS
Old Jul 20, 2004 | 05:02 PM
geterdone's Avatar
geterdone
starting
i had kinda the same problem with my 1990 f250. the staitor module was my answer!
Old Jul 21, 2004 | 12:37 PM
4xFordFreak
anyone else have any ideas??????...... thanks geterdone
Old Jul 21, 2004 | 12:59 PM
ssn randy's Avatar
ssn randy
pressure regulator or fuel pump or fuel filter. fuel pump in-the-tank I think is a low pressure and the one on the fuel rail is high pressure. you should have about 40psi
Old Jul 21, 2004 | 04:24 PM
geterdone's Avatar
geterdone
pressure
the cheapest way would be to try and replace your fuel relay.that is the first thing i did.next to your air filter.
