04 Navigation System
Old Jul 20, 2004 | 10:54 AM
dburanich's Avatar
dburanich
Does anyone know exactly where the GPS antenna is located for the navigation system? I would like to find out if it may be patially blocked from its proper view. I have on several occasions had the system think that it was travelleing on a nearby street which was parallel to the one I was actually travelling. This meant about a 500 ft. discrepancy. These newer units should be accurate to within about 25 feet depending on the signal strength.Something just doesn't seem right. I also have a Garmin 2610 in my other vehicle and it seems to be much more accurate.
Old Jul 20, 2004 | 08:34 PM
FTE Herman's Avatar
FTE Herman
The software that operates these devices attempts to determine which road you are travelling with inputs of calculated heading, calculated route, and proximity. Unfortunately it thinks you are on a different road.
Old Jul 23, 2004 | 07:43 PM
SD Navi's Avatar
SD Navi
You need to goto the setting menu and do a calibration.
This way you can tell it exactly where you are based on landmarks or whatever.
Mine is dead on within 10 ft and its a 2004 Navi.
Old Jul 25, 2004 | 12:47 AM
dburanich's Avatar
dburanich
How do you access the settings menu?
