computer code
Old May 20, 2002 | 06:20 PM
cecil's Avatar
cecil
computer code
p1780 trans control switch out of range
1998 v8 explorer
any ideas?
Old May 20, 2002 | 11:46 PM
FortyFords's Avatar
FortyFords
computer code
p1780 is the code for the overdrive on/off switch/circuit on the gear shift lever.It indicates and open or short or bad switch maybe.
Could also indicate a bad coast clutch
are you seeing any other codes with this?
does your overdrive indicator come on in the I/P when you push the button?
Rich
Ford Trucks Built Tough!
not with rocks
Watch out "X" Mayor of Truckville
Old May 21, 2002 | 04:43 PM
cecil's Avatar
cecil
computer code
not seeing other codes
the i/p od light comes and i am sure the trans od works
Old May 21, 2002 | 07:50 PM
1whteb's Avatar
1whteb
computer code
