Engine sucking sound
Old Jul 19, 2004 | 03:37 PM
taekdown's Avatar
taekdown
Question Engine sucking sound
Hey everyone!
Been reading here for a long time and finally had to ask a ? of my own. I have a 1993 F250 5.8L and I am starting to do small projects , well to my question I did a full tune up and when i tried to replace the fuel filter i could not get it off, well after all the work i did , plugs oil etc... My truck is running good but when i shut it off it makes a two second sucking sound. Like a big slurp by the back of the motor and i can not figure it out. Again it is after i shut it off.
Thank for letting me join, relly nice forum
Wayne from arizona
Old Jul 19, 2004 | 04:44 PM
EPNCSU2006's Avatar
EPNCSU2006
Sounds like a vacuum source relieving vacuum after the engine is shut off. Listen for it with the engine running too, see if you can hear it and trace it down.
Old Jul 19, 2004 | 08:11 PM
5_labsownus's Avatar
5_labsownus
It may be the purge valve letting the charcoal canister pull vapors off the engine.
Some models had a filter to clean the air as it was pulled into the vacuum system.
That may be the sound you hear.
99f350sd
Aerostar
15
Jan 23, 2017 12:48 AM
pyrotvfun
23
Aug 14, 2015 06:13 PM
nickmobile67
33
Jun 28, 2004 09:32 PM
cecoen
Apr 27, 2004 08:10 PM
ScottyB
Apr 6, 2003 12:29 PM
