Hi I have a 93 Aerostar Sport,
hubby was driving home van engine died....pushed it the rest of the way now sitting in my driveway the engine turns over but won't run a friend checked the fuel pump and the gas is going through no problem he sugested check the spark plugs now we have no idea how to get to them on this van does anyone have instructs and pics?? this would help a lot..
Thanks
Sizzz
I don't think it's the plugs. Remove the engine access panel (below dash), pull off the coil wire and check for spark as engine is being cranked. Also remove distributer cap (either keep wires on, or mark their location with tape and pen) and crank engine, noting if the rotor turns - it should.
