hi everone
i have a 72 ford 3/4 ton truck complete rebuilt engine, with a "MSD Ignition". I never had a charging problem tell now. Alternator works fine had it checked. Does anyone have a wiring diagram for the back of the alternator to the starter relay.
thx
P.S.
brake fluid leaks out the top of my master cyl. its new and seems to be some back pressure in the lines. its the 3rd m.c. i bought and the same thing always happens leaks out the cap.
I bought a new one and the battery went dead so i put the old one back in. i had nothing wrong with the charging system tell now. i dont remember how the wires go on the starter relay.
You bought a new starter relay or a regulator? The regulator is usually between the battery and the radiator. The starter relay is on the inner fender to the rear of the battery.
sorry i bought a new regulator thought that was the problem so i put the old regulator back on and no change. I wanted to know what wires go on th battery side of the starter relay and what wires go on the starter side of the starter relay.
it started after i replaced it "the regulator"and took all the wires off the starter relay. how about he back of the alternater how are those wires hooked up? the old regulator is back on
