Sponsored by: Auxito
Bad Heater Core?
Old Jul 19, 2004 | 08:53 AM
Glen Murphy's Avatar
Glen Murphy
Angry Bad Heater Core?
I have a 97 F150xlt extcab 4x4, it has the 4.6l with manual 5 speed.
My question is about fumes in the mornings driving to work, I can see
it comming from vents and defrost, but I'm not seeing any leaks, and the
coolant level hasn't dropped.Thanks for any advice.
Old Jul 19, 2004 | 02:07 PM
PaulC's Avatar
PaulC
Do the fumes have a sweet smell? If so, antifreeze.
Old Jul 19, 2004 | 02:20 PM
Glen Murphy
Yes,I'm pretty sure it's anti-freeze.I was just hoping there might be something I could do to fix it,rather than pulling the dash out to replace the core.I can NOT
believe Ford engineers designed something like that.
Old Jul 19, 2004 | 02:40 PM
jpsage's Avatar
jpsage
Mine went bad (98 e350 superduty class c rv). I was just wondering if you had your radiator serviced lately? I had mine done and the following spring, after not running the rv over the winter, my heater core failed. I have been trying to figure if the shop used some aluminum unfriendly stuff to clean out the radiator.
thanks, john.
Old Jul 19, 2004 | 02:48 PM
Glen Murphy
No, I've not had service done on radiator,I've drained it myself and replaced anti-freeze/water mix.I don't understand how a heater core can just "go bad" .
Did you replace yours yourself?
Old Jul 19, 2004 | 10:26 PM
Racerguy's Avatar
Racerguy
Heater cores do sometimes just "go bad" and start to leak.
Yes it's a pain to replace and I'd like to have a few words with whoever designed the heater on quite a few Fords.
Old Jul 19, 2004 | 11:12 PM
jpsage's Avatar
jpsage
I haven't replaced mine yet. When it happend this spring, I bypassed it and planned on changing it this fall after using the rv this summer. I just lost the engine and can't help but wonder if there was a connection. When I pulled over there was compression going into my overflow tank. It gets towed here tommarrow so I can start tearing it down to find out what happened. I am hoping that it is just a head gasket and nothing else is destroyed.
Good Luck.
john.
