Harmonic Balancer
Old Jul 19, 2004 | 08:21 AM
Celtic Dirk's Avatar
Celtic Dirk
Harmonic Balancer
While installing a new carb I noticed that the stock crank pully was wobbling and needed replacing. Tried FoMoCo and was told not in stock and felt any from salvage yard would be worn also. Contacted CNC and ordered their Balancer PP-800000 Street Damper. It arrived and while the crank hole in damper was the correct size the original pully and damper measured 6 5/8 in diameter and the CNC 7.5. It wouldn't fit. It hit the sharp pointed flange which sticks out form the block. Any ideas/
Old Jul 19, 2004 | 11:08 AM
gtex's Avatar
gtex
There are several FE balancers available, check eBay for the different brands and vendors. You can spend from about $60 to $230 ($230 being the Romac, the popular choice for hot FEs). The only aftermarket pulleys I have found are the March brand you can get at Summit. But, They only offer the 2 pulley setup, that does not accomodate my AC.
