Zf Transmission Interchange question
Old Jul 18, 2004 | 05:09 PM
tampabandit's Avatar
tampabandit
Does anyone know if a ZF Tranny out of a 92 F250 Diesel, will fint my f150 6 cyl, thanks tim
Old Jul 18, 2004 | 09:33 PM
SoCalDesertRider's Avatar
SoCalDesertRider
NO, the ZF has a one piece bellhousing and the diesel/bigblock V8 bellhousing bolt pattern is different than the 6cyl/smallblock V8 pattern. The gears are also higher in the diesel ZF than in the gas models and I believe there is also an issue with the starter mouting on a diesel tranny trying to use on a gas engine. A ZF out of a truck with a 351W/5.8L gas V8 (or 302, if they ever came with one) will work on the 300/4.9L I-6.
