Power window switch problem
Old Jul 18, 2004 | 04:28 PM
akamesnky's Avatar
akamesnky
I've got a little problem with my 1990 E150: the passengers side window works just fine when using the switch on that side. But the drivers switch for the right side window doesn't work. I tried to understand the wiring of the switches and the motor and failed. Besides, the wiring diagram is talking about some 'power window relay' which I failed to locate.
Please help.
Old Jul 18, 2004 | 05:49 PM
Dealford's Avatar
Dealford
Welcome to FTE!
The relay is fine. If not, the windows would not work at all.
Did you open up the boot between the drivers door & the A pillar where all the wiring goes through to look for damage?
AL.
Old Jul 20, 2004 | 09:51 AM
akamesnky's Avatar
akamesnky
Yeah, there is no damage. I am thinking the switch on the passanger side is bad - I ordered one. I will post the follow up if this will not help.
Thank you anyway,
Alex
Old Jul 20, 2004 | 05:44 PM
eselrico's Avatar
eselrico
Had the same problem, it was a bad switch!
Rico
Old Jul 21, 2004 | 10:12 AM
akamesnky's Avatar
akamesnky
Thanks, Rico: it really was a bad switch.
