Rebuilt my carb
Old Jul 18, 2004 | 04:20 PM
MSC's Avatar
MSC
Rebuilt my carb
I rebuilt the carb on my 86 F150 300 I6. It's a remanufactured Holley 1bbl. What would cause it to drip raw gas down the throat after I shut it off? I rechecked the flaot level again. I set it at 3/8" as per the instructions. The motor runs fine, I haven't taken it out on the road yet though. Help Please
Thanks
Mark C.
Old Jul 18, 2004 | 06:53 PM
LWJ's Avatar
LWJ
Did the needle/seat get replaced? The float height is not particularly relevant if the needle does not stop the flow of gas. Not necessarily the correct answer, but a thought.
Larry
Old Jul 19, 2004 | 05:05 PM
MSC's Avatar
MSC
Found the problem. the needle seat wasn't tight enough. Sure helps when you tighten things properly...Duh.
Mark C.
