The other day I finally got my clutch replaced and put everthing back together. It all was fine. I got in my Bronco to start it up and put my foot on the clutch pedal and pushed it and it slammed to the floorboard. I had reach down to lift it and it slammed back up to the pedal stop. I assumed it was something wrong with the mechanical linkage, but everything seems to be ok. Does anyone know why the pedal would be reacting like this? Before I replaced the clutch the pedal worked perfectly normal. When I start the truck in neutral it is fine but with the pedal slammed to the floor when I shift it just grinds gears and kills the engine. Thanks for your help.
1983 Bronco-4 speed manual trans with mechanical linkage
It sounds to me like the fork isn't properly installed in the throwout bearing. If all the linkage, including the z-bar and rod are looking ok, then I would say it is in the bellhousing. Good luck, Ted
I was wondering about the fork. It seems to have a lot of "play" and sometimes falls off the stud that it is supposed to be clipped on. I can move it around up and down when I wiggle it.
