proper pcv set up
Old Jul 18, 2004 | 01:56 AM
hster's Avatar
hster
proper pcv set up
What is the proper pcv set up? The pcv valve screws into the valve cover and a hose goes from the val ve cover to the air filter? This is a 1918 f150 inline 6 cyl.
I am burning alot of oil
please help
thanks
Old Jul 18, 2004 | 10:02 AM
Franken-Truck's Avatar
Franken-Truck
Thats sounds about right. You shouldn't be burning any oil from the PCV system, though, I would think. I would suspect worn piston rings or old valve guide seals. Have you tried any stop leak products in your oil yet? Also, how many miles are on your engine? Also, how do you know its burning oil? Discolored exhuast, or are you just low every few weeks?
Old Jul 18, 2004 | 11:36 AM
5_labsownus's Avatar
5_labsownus
The PCV valve should be in the back of the valve cover and the line from the PCV will run to the vacuum tree in the side of the intake manifold. In the front of the valve cover is the oil fill cap. If the cap has a grommet, it should have a hose to the air cleaner breather element. There should not be any valve in the line from the cap to the breather element.
Old Jul 18, 2004 | 05:16 PM
Franken-Truck
Never mind this post, your right Had to get out my book to double check
Old Jul 20, 2004 | 02:54 PM
83Van's Avatar
83Van
Just make sure the PCV system isn't the source of any vacuum leaks. Something as simple as a bad sealing gasket under the oil filler cap or torn/ old/ worn PCV valve grommet can create enough of a vacuum leak to cut performance, but, it’s not going to make it suck in enough oil to be noticeable.
