Sponsored by: Auxito
Removing A/C compressor
Old Jul 17, 2004 | 02:53 PM
Danielca2's Avatar
Danielca2
98 Ford F-150. How the heck do I get the a/c compressor out of the tight spot its in? I have the bolts out and electrical disconnected but can't find a hole big enough to slip the compressor unit through. Thanks, Danny
Old Jul 17, 2004 | 02:58 PM
TEEJAY's Avatar
TEEJAY
Try turning the steering wheel to move some of the suspension and steering parts that may be blocking it. It should slip out through the bottom. What engine do you have?
Old Jul 17, 2004 | 07:20 PM
Racerguy's Avatar
Racerguy
Hi Daniel and welcome to FTE
Did you figure it out?
If you cant get it out doing what Teejay said you can remove the fan shroud and it will come out the front.
