1978 - 1996 Big Bronco
Transfer case?
Old Jul 17, 2004 | 01:31 PM
elmotho's Avatar
elmotho
Transfer case?
Howdy! My mechanic is telling me that I may need to replace my transfer case. I've got a '96 Bronco 5.8. There seems to be some play in my drive train somewhere and I've been hearing some squealing from the T case and a THUNK when I start/stop. I've replaced motor mounts, front springs, shocks, radius arm bushings. This has helped tighten things up but there is still some movement. My mechanic dosen't see a lot of 4WD vehicles in his shop. Can I get the Tcase repaired? Or should it be replaced? Should I go rebuilt? Thanks mucho!
Old Jul 17, 2004 | 01:35 PM
RLKBOB's Avatar
RLKBOB
If he doesn't have much 4wd experience I wouldn't take it to him, find somebody else. Sounds like u-joints.
Old Jul 17, 2004 | 03:42 PM
cactusbronco's Avatar
cactusbronco
My 95 XLT was "Thunking" whenever I would start and stop untill I saw a post on here about it. Take the driveshaft off and grease the slip joint. After I did that it the Thunking was gone!
Old Jul 17, 2004 | 03:57 PM
Zoomie331r's Avatar
Zoomie331r
I had thunk when I took off or let up off throttel in drive train it was U joints
Old Jul 18, 2004 | 04:18 AM
mustangman65_79's Avatar
mustangman65_79
U-Joints, I think the T-case is direct to the rear shaft. U should have 3 rear joints, plus a "CV" joint. Inside of the housing for the forward U-joints, on the rear shaft, there is a little Ball bearing looking thing, that is prob shot. Only NAPA carrys these *****. Part # 615.
