I'm Planning on doing a efi 460/5 speed conversion from my 302/5 seed. How much stuff can I get from the yard? I already plan on the L&L mounts. Also, would it be worth my time to convert it to the mass air? I plan on eventually gettin the vortec charger for it. Any advice would be great.
~Kevin
What year is your truck? I assume 87 or newer being you have a 5 speed...
Don't even bother with the L&L mounts, everything you need to put a 460 in there, save the remote mount oil filter setup(the factory Ford filter adapter will apparently hit the F150 engine crossmember) is junkyardable, or avalable from Ford yet.
